CAN post funtions and VALIDATORS be migrated with workflow.
siva
while exporting a workflow postfunctions and validators that are added using plug ins are not copied .
IS there any workaround to copy postfunctions and validator when workflow is exported.
David Fischer
They are if you export the workflow as XML (it’s one of the two options available)
Learn more
