CPU High Alert Jira server
Soporte Atlassian Ferrovial January 11, 2024
After migration to cloud, we have set server enviroment to read only.
But our server instance is showing  we have received an alert from the azure monitor about the memory usage from the CPU. Why is this happening? could you please help us to analyze the log?
We can see some warnings at the logs,
08-Jan-2024 07:00:05.608 WARNING [jmxtrans-agent-1] org.jmxtrans.agent.GraphitePlainTextTcpOutputWriter.writeQueryResult Exception sending 'Jira.PRO.azlrhpjira01.tomcat.Servlet.maxTime 0 1704693605' to HostAndPort{host='hflnxvmucm01', port=2003}
java.net.SocketException: Broken pipe (Write failed)
at java.net.SocketOutputStream.socketWrite0(Native Method)
at java.net.SocketOutputStream.socketWrite(SocketOutputStream.java:111)
at java.net.SocketOutputStream.write(SocketOutputStream.java:155)
at sun.nio.cs.StreamEncoder.writeBytes(StreamEncoder.java:221)
at sun.nio.cs.StreamEncoder.implWrite(StreamEncoder.java:282)
at sun.nio.cs.StreamEncoder.write(StreamEncoder.java:125)
at sun.nio.cs.StreamEncoder.write(StreamEncoder.java:135)
at java.io.OutputStreamWriter.write(OutputStreamWriter.java:220)
at java.io.Writer.write(Writer.java:157)
at org.jmxtrans.agent.GraphitePlainTextTcpOutputWriter.writeQueryResult(GraphitePlainTextTcpOutputWriter.java:109)
at org.jmxtrans.agent.OutputWriterCircuitBreakerDecorator.writeQueryResult(OutputWriterCircuitBreakerDecorator.java:89)
at org.jmxtrans.agent.OutputWritersChain.writeQueryResult(OutputWritersChain.java:49)
at org.jmxtrans.agent.Query.collectAndExport(Query.java:174)
at org.jmxtrans.agent.JmxTransExporter.collectAndExport(JmxTransExporter.java:155)
at org.jmxtrans.agent.JmxTransExporter$2.run(JmxTransExporter.java:115)
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511)
at java.util.concurrent.FutureTask.runAndReset(FutureTask.java:308)
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$301(ScheduledThreadPoolExecutor.java:180)
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:294)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624)
at java.lang.Thread.run(Thread.java:748)
08-Jan-2024 07:00:05.610 WARNING [jmxtrans-agent-1] org.jmxtrans.agent.Query.collectAndExport Exception collecting Catalina:j2eeType=Servlet,WebModule=//localhost/jira,name=jsp.decorators.panel_002dadmin_jsp,J2EEApplication=none,J2EEServer=none#maxTime
08-Jan-2024 07:00:05.649 WARNING [jmxtrans-agent-1] org.jmxtrans.agent.GraphitePlainTextTcpOutputWriter.writeQueryResult Exception sending 'Jira.PRO.azlrhpjira01.tomcat.Servlet.maxTime 0 1704693605' to HostAndPort{host='hflnxvmucm01', port=2003}
java.net.ConnectException: Exception connecting to HostAndPort{host='hflnxvmucm01', port=2003}
09-Jan-2024 08:48:38.651 SEVERE [https-jsse-nio-8443-exec-22634] com.sun.jersey.spi.container.ContainerResponse.mapException Exception mapper com.atlassian.plugins.rest.common.security.jersey.SecurityExceptionMapper@1634c673 for Throwable com.atlassian.plugins.rest.common.security.AuthenticationRequiredException: Client must be authenticated to access this resource. threw a RuntimeException when attempting to obtain the response
09-Jan-2024 08:48:38.662 SEVERE [https-jsse-nio-8443-exec-22634] com.sun.jersey.spi.container.ContainerResponse.logException Mapped exception to response: 500 (Internal Server Error)
javax.ws.rs.WebApplicationException: java.text.ParseException: String, es-419, is not a valid language tag
at com.sun.jersey.server.impl.model.HttpHelper.clientError(HttpHelper.java:273)
at com.sun.jersey.server.impl.model.HttpHelper.getAcceptLanguage(HttpHelper.java:228)
at com.sun.jersey.server.impl.VariantSelector.selectVariant(VariantSelector.java:290)
at com.sun.jersey.spi.container.ContainerRequest.selectVariant(ContainerRequest.java:696)
at com.sun.jersey.spi.container.AdaptingContainerRequest.selectVariant(AdaptingContainerRequest.java:286)
at sun.reflect.GeneratedMethodAccessor2736.invoke(Unknown Source)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.lang.reflect.Method.invoke(Method.java:498)
at com.sun.jersey.server.impl.application.WebApplicationImpl$2.invoke(WebApplicationImpl.java:301)
at com.sun.proxy.$Proxy5707.selectVariant(Unknown Source)
at com.atlassian.plugins.rest.common.Status.variantFor(Status.java:304)
at com.atlassian.plugins.rest.common.security.jersey.SecurityExceptionMapper.toResponse(SecurityExceptionMapper.java:22)
at com.atlassian.plugins.rest.common.security.jersey.SecurityExceptionMapper.toResponse(SecurityExceptionMapper.java:16)
at com.sun.jersey.spi.container.ContainerResponse.mapException(ContainerResponse.java:480)
at com.sun.jersey.server.impl.application.WebApplicationImpl._handleRequest(WebApplicationImpl.java:1479)
at com.sun.jersey.server.impl.application.WebApplicationImpl.handleRequest(WebApplicationImpl.java:1419)
at com.sun.jersey.server.impl.application.WebApplicationImpl.handleRequest(WebApplicationImpl.java:1409)
at com.sun.jersey.spi.container.servlet.WebComponent.service(WebComponent.java:409)
at com.sun.jersey.spi.container.servlet.ServletContainer.service(ServletContainer.java:558)
at com.atlassian.plugins.rest.module.RestDelegatingServletFilter$JerseyOsgiServletContainer.doFilter(RestDelegatingServletFilter.java:162)
at com.sun.jersey.spi.container.servlet.ServletContainer.doFilter(ServletContainer.java:829)
at com.atlassian.plugins.rest.module.RestDelegatingServletFilter.doFilter(RestDelegatingServletFilter.java:72)
at com.atlassian.plugin.servlet.filter.DelegatingPluginFilter.doFilter(DelegatingPluginFilter.java:62)
at com.atlassian.plugin.servlet.filter.IteratingFilterChain.doFilter(IteratingFilterChain.java:37)
at com.atlassian.plugin.servlet.filter.ServletFilterModuleContainerFilter.doFilter(ServletFilterModuleContainerFilter.java:56)
at com.atlassian.plugin.servlet.filter.ServletFilterModuleContainerFilter.doFilter(ServletFilterModuleContainerFilter.java:44)
at com.atlassian.plugin.servlet.filter.DelegatingPluginFilter.lambda$doFilter$0(DelegatingPluginFilter.java:57)
at com.atlassian.plugins.rest.module.servlet.RestServletUtilsUpdaterFilter.doFilterInternal(RestServletUtilsUpdaterFilter.java:23)
at com.atlassian.plugins.rest.module.servlet.RestServletUtilsUpdaterFilter.doFilter(RestServletUtilsUpdaterFilter.java:35)
at com.atlassian.applinks.core.rest.context.ContextFilter.doFilter(ContextFilter.java:24)
at com.atlassian.servicedesk.internal.web.ExternalCustomerLockoutFilter.doFilter(ExternalCustomerLockoutFilter.java:55)
at com.atlassian.core.filters.AbstractHttpFilter.doFilter(AbstractHttpFilter.java:32)
at com.atlassian.jira.plugin.mobile.web.filter.MobileAppRequestFilter.doFilter(MobileAppRequestFilter.java:59)
at com.atlassian.jira.plugin.mobile.login.MobileLoginSuccessFilter.doFilter(MobileLoginSuccessFilter.java:54)
at com.atlassian.mywork.client.filter.ServingRequestsFilter.doFilter(ServingRequestsFilter.java:32)
at com.atlassian.diagnostics.internal.platform.monitor.http.HttpRequestMonitoringFilter.doFilter(HttpRequestMonitoringFilter.java:55)
at com.atlassian.analytics.client.filter.UniversalAnalyticsFilter.doFilter(UniversalAnalyticsFilter.java:75)
at com.atlassian.analytics.client.filter.AbstractHttpFilter.doFilter(AbstractHttpFilter.java:33)
at com.atlassian.web.servlet.plugin.request.RedirectInterceptingFilter.doFilter(RedirectInterceptingFilter.java:21)
at com.atlassian.prettyurls.filter.PrettyUrlsSiteMeshFixupFilter.doFilter(PrettyUrlsSiteMeshFixupFilter.java:32)
at com.atlassian.prettyurls.filter.PrettyUrlsDispatcherFilter.doFilter(PrettyUrlsDispatcherFilter.java:55)
at com.atlassian.prettyurls.filter.PrettyUrlsSiteMeshFilter.doFilter(PrettyUrlsSiteMeshFilter.java:80)
at com.atlassian.prettyurls.filter.PrettyUrlsMatcherFilter.doFilter(PrettyUrlsMatcherFilter.java:51)
at com.atlassian.labs.botkiller.BotKillerFilter.doFilter(BotKillerFilter.java:35)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:193)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:166)
at com.atlassian.jira.web.filters.MobileAppRequestFilter.doFilter(MobileAppRequestFilter.java:36)
at com.atlassian.jira.web.filters.accesslog.AccessLogFilter.executeRequest(AccessLogFilter.java:93)
at com.atlassian.jira.web.filters.accesslog.AccessLogFilter.doFilter(AccessLogFilter.java:79)
at com.atlassian.jira.web.filters.pagebuilder.PageBuilderFilter.doFilter(PageBuilderFilter.java:81)
at com.atlassian.jira.web.filters.CommittedResponseHtmlErrorRecoveryFilter.doFilter(CommittedResponseHtmlErrorRecoveryFilter.java:55)
at com.atlassian.plugin.servlet.filter.IteratingFilterChain.doFilter(IteratingFilterChain.java:39)
at com.exalate.transport.rest.server.resourcefilter.CORSFilter.doFilter(CORSFilter.java:37)
at com.atlassian.oauth2.scopes.web.ReadWriteScopeFilter.doFilter(ReadWriteScopeFilter.java:46)
at com.atlassian.ratelimiting.internal.filter.RateLimitFilter.doFilter(RateLimitFilter.java:73)
at com.atlassian.troubleshooting.thready.filter.AbstractThreadNamingFilter.doFilter(AbstractThreadNamingFilter.java:46)
at com.atlassian.prettyurls.filter.PrettyUrlsCombinedMatchDispatcherFilter.doFilter(PrettyUrlsCombinedMatchDispatcherFilter.java:56)
at com.quisapps.jira.fieldsecurity.filter.FieldSecurityFilter.doFilterChainWithProfiling(FieldSecurityFilter.java:277)
at com.quisapps.jira.fieldsecurity.filter.FieldSecurityFilter.doFilterInterval(FieldSecurityFilter.java:127)
at com.quisapps.jira.fieldsecurity.filter.FieldSecurityFilter.doFilter(FieldSecurityFilter.java:70)
at com.atlassian.jira.security.xsrf.XsrfTokenAdditionRequestFilter.doFilter(XsrfTokenAdditionRequestFilter.java:46)
at com.atlassian.jira.web.filters.MauEventFilter.doFilter(MauEventFilter.java:49)
at com.atlassian.jira.security.JiraSecurityFilter.lambda$doFilter$0(JiraSecurityFilter.java:66)
at com.atlassian.seraph.filter.SecurityFilter.doFilter(SecurityFilter.java:242)
at com.atlassian.jira.security.JiraSecurityFilter.doFilter(JiraSecurityFilter.java:64)
at com.atlassian.security.auth.trustedapps.filter.TrustedApplicationsFilter.doFilter(TrustedApplicationsFilter.java:94)
at com.atlassian.seraph.filter.BaseLoginFilter.doFilter(BaseLoginFilter.java:148)
at com.atlassian.jira.web.filters.JiraLoginFilter.doFilter(JiraLoginFilter.java:77)
at com.atlassian.oauth.serviceprovider.internal.servlet.OAuthFilter.doFilter(OAuthFilter.java:67)
at com.atlassian.plugins.rest.module.servlet.RestSeraphFilter.doFilter(RestSeraphFilter.java:38)
at com.atlassian.pats.web.filter.TokenBasedAuthenticationFilter.doFilter(TokenBasedAuthenticationFilter.java:83)
at com.atlassian.oauth2.provider.core.web.AccessTokenFilter.doFilter(AccessTokenFilter.java:77)
at ru.andreymarkelov.atlas.plugins.promjiraexporter.servlet.AllEndpointFilter$1.run(AllEndpointFilter.java:44)
at ru.andreymarkelov.atlas.plugins.promjiraexporter.service.MetricCollectorImpl.requestDuration(MetricCollectorImpl.java:283)
at ru.andreymarkelov.atlas.plugins.promjiraexporter.servlet.AllEndpointFilter.doFilter(AllEndpointFilter.java:39)
at com.atlassian.jira.web.filters.johnson.JiraJohnson503Filter.doFilter(JiraJohnson503Filter.java:79)
at org.tuckey.web.filters.urlrewrite.RuleChain.handleRewrite(RuleChain.java:176)
at org.tuckey.web.filters.urlrewrite.RuleChain.doRules(RuleChain.java:145)
at org.tuckey.web.filters.urlrewrite.UrlRewriter.processRequest(UrlRewriter.java:92)
at org.tuckey.web.filters.urlrewrite.UrlRewriteFilter.doFilter(UrlRewriteFilter.java:394)
at com.atlassian.jira.servermetrics.CorrelationIdPopulatorFilter.doFilter(CorrelationIdPopulatorFilter.java:30)
at com.idalko.tgng.jira.server.models.servicedesk.ServletRequestContextFilter.doFilter(ServletRequestContextFilter.scala:12)
at com.atlassian.servicedesk.internal.web.CustomerContextSettingFilter.lambda$invokeFilterChain$0(CustomerContextSettingFilter.java:220)
at com.atlassian.servicedesk.internal.api.util.context.ReentrantThreadLocalBasedCodeContext.rteInvoke(ReentrantThreadLocalBasedCodeContext.java:136)
at com.atlassian.servicedesk.internal.api.util.context.ReentrantThreadLocalBasedCodeContext.runOutOfContext(ReentrantThreadLocalBasedCodeContext.java:89)
at com.atlassian.servicedesk.internal.utils.context.CustomerContextServiceImpl.runOutOfCustomerContext(CustomerContextServiceImpl.java:47)
at com.atlassian.servicedesk.internal.web.CustomerContextSettingFilter.outOfCustomerContext(CustomerContextSettingFilter.java:211)
at com.atlassian.servicedesk.internal.web.CustomerContextSettingFilter.doFilterImpl(CustomerContextSettingFilter.java:139)
at com.atlassian.servicedesk.internal.web.CustomerContextSettingFilter.doFilter(CustomerContextSettingFilter.java:128)
at com.atlassian.plugins.authentication.basicauth.filter.DisableBasicAuthFilter.doFilter(DisableBasicAuthFilter.java:70)
at com.atlassian.analytics.client.filter.JiraAnalyticsFilter.doFilter(JiraAnalyticsFilter.java:30)
at com.atlassian.jwt.internal.servlet.JwtAuthFilter.doFilter(JwtAuthFilter.java:37)
Nic Brough -Adaptavist-
January 11, 2024
How have you "set the server environment to read only"?  There are two ways to do it, but the errors you are getting look like you have tried to do it with another change.
Soporte Atlassian Ferrovial January 12, 2024
Hello Nic!
thanks for your help
We've set in all the projects a permission scheme with only read settings. The only permission that has the user is "Browse projects" so they can still see their issues.
Thank you
January 12, 2024
Ah, good, that's one of the two correct ways to do it (the other is to find an old expired trial licence and apply it to your server - servers with an invalid trial licence work fine, except that you can't create, edit, or transition, issues, and some admin functions go read-only as well)
Your errors could be pointing to the wrong way to do it (making things read-only in the database), so I had to ask!
The errors could also be down to an automation, script, regular job, or even a field - you can configure things that connect to other systems.  As you've moved, I expect your new system will have been connected to these systems, and the connection from the old server blocked, but it looks like the old server is still trying to use them, and it might be chewing up memory with all the re-tries.  These remote systems may include the Jira server itself, where things might be failing because you can't log into it with an account that can do the writes it is trying!
Have a look through the logs in general, not just the snippets here (although they are useful to help us find the problem, the full log might tell you a lot more).  I know the logs are long and impenetrable to read, so I would cheat - open them in a text editor of some sort and search for "http" and "host" in two runs.  This should tell you about the connections!
Soporte Atlassian Ferrovial January 19, 2024
Hi Nic,
We reviewed the logs and we found errors about the reports. We have disabled the outgoing mail, also we have disabled the following plugins in case it was trying , Scriptrunner, Exalate, Jenkins, Jira Suite Utilitties etc..) but we are with the same problem! :(
January 19, 2024
Are you still seeing errors connecting to HTTP or hosts?  Can you identify what those machines are running that it might be trying to connect to?
