CSRF token verification failed when using external API in Script Runner (Jira Data Center)
Ekaterina Berezutskaya
I’m using external API in Script Runner (Jira Data Center).
  1. I need to get a csrf-token from an external system using GET method
  2. Then I have to use this token (obtained from GET method) in POST method
I have groovy scrip which I run from the console:
final url = "remote link"
final String username = "xxx user"
final String password = "xxx password"
final json = """
    "xxx": "x",
    "yyy": "y",
    "zzz": 1111
String token = null
//getting csrf-token. GET returns token in Headers
try
    final URL get = new URL(url)
    final HttpURLConnection connection = (HttpURLConnection) get.openConnection()
    connection.setRequestMethod("GET")
    connection.doOutput = true
    connection.setRequestProperty('Content-Type', 'application/json')
    connection.setRequestProperty('Accept', 'application/json')
    String authString = "${username}:${password}"
    String authStringEncoded = authString.bytes.encodeBase64().toString()
    connection.setRequestProperty('Authorization', "Basic ${authStringEncoded}")
    connection.setRequestProperty('x-csrf-token', 'fetch')
    connection.connect()
    def res = connection.getResponseCode();
    if(res.equals(200) || res.equals(201))
        token = connection.getHeaderField('x-csrf-token')
    connection.disconnect()
catch(Exception ex)
    log.error(ex.message)
if (token == null){
    return
//POST
try{
    final URL post = new URL(url)
    final HttpURLConnection connection = (HttpURLConnection) post.openConnection()
    connection.setRequestMethod("POST")
    //token
    connection.setRequestProperty('x-csrf-token', token)
    connection.getOutputStream().write(json.getBytes("UTF-8"))
    def postRC = connection.getResponseCode();
    log.warn(postRC)
    if(postRC.equals(200))
        log.info(connection.getInputStream().getText());
catch(Exception ex1)
    log.error(ex1.message)
POST method returns an error 401: CSRF token verification failed.
I suspect that after closing the GET connection, the token becomes invalid and I can't use it in the POST request. Does anyone know how to solve this problem?
4 votes
UPD. I found a solution. In this case, I had to use the HttpClient class instead of the HttpURLConnection class
SERVER
