CSV Import - Attachment URL Not Importing
Sarah Shepard
December 20, 2017 edited
I have run several CSV imports with success. I added an attachment column and mapped it using an https:// link to an item in our Google Drive account. It imported but came across as "Open" or edit with no attachment. Any ideas?
Thanks so much!
Edwin Kyalangalilwa
December 20, 2017
Hi Sarah,
The attachments might be password protected, hence JIRA can't access them. Are you using Server or Cloud?
Sarah Shepard
Cloud.
I assumed that since I created the test ticket for myself and didn't log out, I should be able to click on an attachment link I created since I don't need to "log in" to be directed to the url.
Edwin Kyalangalilwa
December 20, 2017
I meant on the Google Drive side.
Can you see the attachments on your browser using the URL and not logging in?
Sarah Shepard
I see. So if I open a new browser, not logged in to Google, then no I cannot see it. It takes me to the google log in screen.
Edwin Kyalangalilwa
That won't work then. You can download them locally and update your attachment links as so. Either in the current directory
file://file.jpeg
or a path
file:///folder/file.jpeg
https://confluence.atlassian.com/cloudkb/importing-attachments-into-jira-cloud-using-csv-691011888.html
Sarah Shepard
Bummer! Ok thanks so much for your help!
Sravan Kumar January 26, 2018
@Edwin Kyalangalilwa
I am facing the same issue, Could you please help me how could I update the file/ attachment Link to the path: file://file.jpeg??
I am not clear to what can be done so I could have a successful Imports with Attachments. Please Advice!!
Aashish Gupta
I uploaded the attachment on a shared location with the csv file which was supposed to be imported. Both the CSV file and image file were uploaded on the same location but when the import process was started it errored out as -
"Attachment file not found or not readable, skipping: /app_2/var/atlassian/application-data/jira/import/attachments/JIRA.png".
Just to mention the above process was tried with keeping the files on my desktop as well but it threw the same error.
Can someone please help to resolve this?
Kamal Kailasa Babu March 5, 2020
is this solved?
Annie Brousseau
April 20, 2020
I'm also looking for a solution to this issue. Trying to import from a JSON file. File to attach is in the same folder. My json looks like that:
"attachments": [
"name": "Attach.msg",
"attacher": "user1",
"created": "2020-04-20T09:51:12.1681238+08:00",
"description": "This is a test",
"uri": file://Attach.msg
Still getting the issue:
org.codehaus.jackson.JsonParseException: Unrecognized token 'file': was expecting
P SRINIVASA RAO
March 1, 2018
Hi Edwin,
Here we are migrated jira issues from one cloud instance to other,we've mapped the attachments column also,import done ,attachments are attached to the issues but i'm unable to view the attachments, Here i'm attaching the screenshot for your reference,Please provide any solution to migrate the attachments or to view the imported attachments.image.png
Edwin Kyalangalilwa
March 3, 2018
You'll have to download the attachment files separately and then do a import. They won't be brought in with the CSV import. Let me know if that helps.
Screen Shot 2018-03-03 at 19.52.00.png Screen Shot 2018-03-03 at 19.52.17.png
rbalusu3 March 22, 2018
Please add "Anyone" group to Browse Project permission in Permission schema and import the  CSV format. So while importing it will not check any authentication and download the attachment from Source and upload into Target server. I have done it and it is working fine.
Regards
Ravi
Julian Governale
December 7, 2018
This did not work for us.  The attachments are uploaded but they are not viewable.
Julian Governale
July 5, 2019
Not sure if this solution works for everyone, but we used an Extranet SharePoint site. This site had general public access so everyone could view the site.  Once we mapped out attachment URL to that public site, and before importing i checked with a personal account i could see the attachments without logging into the Sharepoint site, we imported and it worked just fine.    They key is even if its a public site, we found that the site needs no authentication at all for the attachments to import as expected.  If you have to log into a site to access the attachments or download them, then it may not work.  If you can download them without logging in, then it should work.
Sravan Kumar January 26, 2018 edited
Tried by uploading the files through Google Drive and by the below process.. Both are throwing the same error:
  1. Attached all the Attachments into a test issue in Jira
  2. Copied the URL's of attachments
  3. Pasted the URLS in the Attachment Column in my CSV File
  4. Imported them through CSV importer
Edwin Kyalangalilwa
January 26, 2018
Hi Sravan,
This process is not possible when importing from Google Drive. You'll have to get the files to your local computer and then you can use the file://file.jpeg.
Like • Julie Prolhac likes this
Sravan Kumar March 23, 2018
Edwin,
This has worked: Thank you! we are migrating huge data.. about 10,000 issues with more than 2000 attachments in it.. Is there a way to bulk import the attachments? saving each and every attachment locally for 2000 attachments will take it for ever.. I was looking if there is any workaround for this..
Please Advice.
Thank You!!
Like • Wayne Lu likes this
Julie Prolhac July 5, 2019
@[deleted] @Edwin Kyalangalilwa : could you please help me as well? I am trying to upload several JIRA tickets using Service Desk cloud in csv format with attachments from local computer. Edwin you presented the solution for files located in current directory
file://file.jpeg
or a path
But I don't manage to do it. In the csv file I am using following link format to a file located on my computer. For example:
file:///C:/Users/Julie/Documents/81_JIRA/image.jpg
What am I doing wrong?
Thank you so much in advance!
Julie
Edwin Kyalangalilwa
July 5, 2019
Hi @Julie Prolhac ,
The URI looks correct for a Windows environment. I'll have to test an actual import on Windows to confirm.
Have you tried from the same directory?
Julie Prolhac July 8, 2019 edited
Hi @Edwin Kyalangalilwa ,
Yes i tried from the same directory where the ticket upload csv file was. It is located in C:/temp and the file iiself is user.png. I tried both entries:
file:///C:/temp/user.png
file://user.png
but both returned following log:
Attachment file not found or not readable, skipping: /data/jirastudio/jira/home/import/attachments/C:/temp/user.png
Would you know what i am doing wrong? any way to change the first part of the path that is added automatically? /data/jirastudio/jira/home/import/attachments/
Thank you for your time!!
Julie
Edwin Kyalangalilwa
July 9, 2019
@Julie Prolhac ,
It's not possible to remove the first part of the path. This is the path where Jira is looking for attachments. Not where the CSV file is located.
When you specify
file://user.png
It's looking for
/data/jirastudio/jira/home/import/attachments/user.png
So you'll first import the attachments and then reference them in the import.
Julie Prolhac July 18, 2019
Understood now! thank you @Edwin Kyalangalilwa !
Like • Edwin Kyalangalilwa likes this
Manju A
September 20, 2019 edited
@Edwin Kyalangalilwa - I did try placing the file under the location
"/data/jirastudio/jira/home/import/attachments/"
but still i am getting the Exception as File not found Exception. My Jira is in cloud hosted.
Does that mean i have to load all my attachments to the cloud server where Jira is installed?
I need all attachments to be uploaded as part of CSV import, from my local system and not from cloud. Any options would help.
Manjunath
Julian Governale
September 20, 2019
@Manju A if using jira cloud atlassian hosts your instance and you cant access the server.
I got this working by hosting all the file on a public site that reachable with no authentication.  Once imported, make sure to delete the files from this site
And when i say public site, i literally mean anyone in the world can see the attachments if they have the URL.
Store the attachments locally did not work for me since we are on a work domain and Jira cant authenticate to it so they could never access the file locally on my machine.
Manju A
September 20, 2019
Thanks Julian for the quick response. Publicly available site is Scary and cant go with it since Org. policy doesnt allow it.
I was thinking another option "using Jira API" to upload files. Would that work? Before I can invest time on this API approach would like your blessings :-)
Appreciate your response.
Manjunath
Julian Governale
September 20, 2019
I have never used the API to do this.  We have sharepoint here in our org and we created and external document library that allowed anonymous access which worked for our needs.  Sorry i cant help more on the API side.
Imran Mansuri
April 17, 2024
@edwin, when you say "First import the attachments", I want to ask where I can import bulk files in JIRA. I am importing issues through CSV files, but the problem is, that the system is finding attachments in the JIRA attachments folder, whereas attachments are stored on publicly accessed URLs, can you please help me in this matter?
