×In reviewing the documentation for the CSV Import function it indicates that you can import multiple values to Multiselect fields:
Your CSV file can contain multiple entries for the one Multi Select Custom Field. For example:
1 2
Summary,Multi Select,Multi Select,Multi Select Sample issue,Value 1,Value 2,Value 3
This will populate the Multi Select Custom Field with multiple values.
When I attempted to do this I received an error referencing that None was not a value (I did not take a screenshot). I believe this resulted as the number of values in the source data varies from 1 to 6. This means I have 6 columns of data for this field in the source file however many of these cells are empty. For empty cells do I need to have a value in these e.g. "None"? I recall seeing the starting value for the Multiselect field as None when I was editing the values but this does not appear in the Issue in View, Edit or Create mode. Thanks in advance.
You should not need to supply values for the issues which have fewer than 6 values. Can you please try again and supply a screenshot?
Kian
@Kian Stack Mumo Systems I finally got back to this issue and discovered through testing various things that I have missed value in my JIRA list that was in the source data which was causing the issues. I have added the value and my upload work. Thanks for your help.
