CSV Import
Vyshnavi Bandarupalli February 19, 2019
"Project","Key","Summary","T","Status","P","Resolution","Assignee","Reporter","Creator","Created","Last Viewed","Updated","Resolved","Affects Version/s","Fix Version/s","Components","Due"
"Database Support","DBA-5257","Shut down the two 10g DR Wealth databases ","Disaster Recovery","Done","Minor","Done","Shailendra Srivastava","Divesh Jagannath","Divesh Jagannath","26/Feb/2018","lastViewed not supported yet","05/Mar/2018","05/Mar/2018","","","",""
Getting error like Affects Version/s(e.g.First row doesn't have a value)
How to import empty values ?
Vijay Sv
Hi, Check if you have defined Affects Version/s in the project that you're trying to import to and/or if it is mandatory value in your project. Thanks.
