Calculate a custom field value
Stephanie Laeng August 5, 2012
we want to calculate a field value regarding two other custom fields.
Is it possible to calculate a value of a custom field regarding a matix of two other field values?
Regards
Steffi
Christian Czaia [Decadis AG]
August 6, 2012
Hey,
not by default. I would check the following plugins:
Jamie's behaviours plugin (using groovy scripts)https://studio.plugins.atlassian.com/wiki/display/JBHV/JIRA+Behaviours+Plugin
I guess you could do the same with his script runner plugun (as a workflow post-function)
https://marketplace.atlassian.com/plugins/com.onresolve.jira.groovy.groovyrunner
Another workflow tool that is capable of calculation operations:
https://marketplace.atlassian.com/plugins/com.fca.jira.plugins.workflowToolbox.workflow-toolbox
That's the last one I have in mind right now:
https://marketplace.atlassian.com/plugins/com.keplerrominfo.jira.plugins.keplercf
I've been using the behaviours plugin and the workflow toolbox.
Hope you can use any of these.
Cheers
Christian
August 6, 2012
The behaviours plugin can do calculations in real-time!
February 18, 2013
Could you use any of these?
Pranjal Shukla
Also,
Please have a look at how Calculated Custom Field is implemented. Yo will get lot many examples on the internet and then you can create your own. We use a lot of them.
