Calculate days between dates
Dan Flint
October 29, 2012
I want to be able to calculate the number of days between two dates and store the value in a field that can be used within a filter. This can be calculated and stored based on workflow as it would be calculated on the closure of the issue.
Javascript or free plugin in suggestions are welcome.
Thanks in advance
Dan
Dan Flint
November 5, 2012
I used Kepler custom fields and a sil script custom field to acheive what was required.
Note: this does not return the days but the minutes between the dates, this needs to be divided by (60*working hours in a day as set in system*number of working days in the system) to provide the days.
Christopher Gronde
I use a script field in Script Runner
import com.atlassian.jira.component.ComponentAccessor;
import com.atlassian.jira.issue.Issue;
import  java.util.Date.*
def customFieldManager = ComponentAccessor.getCustomFieldManager();
def dateFieldObject= customFieldManager.getCustomFieldObject('customfield_15968');
def dateFieldObject2= customFieldManager.getCustomFieldObject('customfield_15967');
if(issue.getCustomFieldValue(dateFieldObject) && issue.getCustomFieldValue(dateFieldObject2)) {
   def dateValue = issue.getCustomFieldValue(dateFieldObject) as Date
   def dateValue2 = issue.getCustomFieldValue(dateFieldObject2) as Date
   def calculation = (dateValue - dateValue2)
   return (calculation as String)
Jobin Kuruvilla [Adaptavist]
October 29, 2012
Look at scripted fields from Script runner plugin.
atlassian, loom, AI, meeting recording, community
[NEW] Record your meetings with Loom
Welcome to great meetings, with less work. Automatically record, summarize, and share instant recaps of your meetings with Loom AI.
Learn more
