Calculate due date based on Original Estimate
Liz T
Use Case: We are using the Original estimate field to estimate how long a task should take. Ex: Original estimate = 3w
We'd like the End date to update when somebody updates the Start date on a task, based on the Original estimate.
Ex: Start date 11/3/2022 + Original estimate 3w = End date  (11/24/2022)
Question: Does anybody have a suggestion on how I could create this automation?
I got this far:
>>When field value changed --start date
>>then edit issue --due date
but then don't know what to put in...I've tried various JQL, but can't get it to work.
Would this need to be a JQL or should it actually be JSON?
Alex Koxaras -Relational-
Liz T
Thank you!!
Liz T
November 3, 2022 edited
@Alex Koxaras -Relational- It worked! I really appreciate your help : )
