Calculate sum of values from linked issues using JIRA Workflow toolbox
Laura Snoeij [Test QPS] July 9, 2018
Hi all,
I like to find a solution with the add-ons I already have installed.
I have an issue with multiple linked issues. The linked issues all have the same  custom field.
What I try to achieve is to create a field in the "main" issues which sums up all the values from the custom field in the linked issues.
Could this be done with the JIRA Workflow Toolbox?
Anton Chemlev - Toolstrek -
July 9, 2018
Hi Laura,
Have you already checked this page - https://apps.decadis.net/display/JWT/Calculated+Number+Field ? Especially,
Example 4. It seems you can use "linkedIssues" instead of subtasks.
Help us plant more trees
