Is anyone else getting an error when trying to use this code? I found it in the
library
def issueType = "Service Request with Approvals" // only display the sum on this issue type
def linkedIssueType = "Sub-task" // calculates for all linked issues of this type
def customField = "SLA NEW DUE DATE" // the custom field that you want to sum up
if (issue.getIssueType().name == issueType) {
def issueLinkManager = ComponentAccessor.getIssueLinkManager()
def sum = 0
issueLinkManager.getOutwardLinks(issue.id).each {issueLink ->
def linkedIssue = issueLink.getDestinationObject()
if (linkedIssue.getIssueType().name == linkedIssueType) {
def technicalPointsField = customFieldManager.getCustomFieldObjectsByName(customField)[0]
sum += linkedIssue.getCustomFieldValue(technicalPointsField)?:0
return sum
Hello Jacob.
If you want to try, there some just done scripts in Groovy for this your requirement specifically to work with custom fields in tasks (like time spent or whathever) and sub-tasks.
You can look at: https://github.com/GTessarini/JiraAutomations
I hope help you!
Regards
Gabriel Tessarini
Hello @Jacob francois
This is static type checking error, you can ignore it. It appears because getCustomFieldValue can return various types of result like ApplicationUser, Integer, Options etc. and compiler doesn't know which one, so error appears.
Hi Mark,
I am also facing same issue, even if I ignore static type checking error, its not working.
Please suggest a solution.
Sravani
Make the most of your time in Barcelona with our curated guide – discover how Jira, Confluence, Loom, and Rovo work better together, connect with Atlassian experts, and enter to win an Apple prize bundle!
Get the guide
