Hello Community
I'm an Easzybi noob, so please bear with me..
I'm hoping someone can help with this. We have a custom field dimension called PMO Projects for Project number filtering. It has 3 main default entries of "Baseline", "All PMO Projects" &"non-project Discretionary". Then the rest are all the separate Project number listings of which there are dozens.
What I'm trying to do is create a 4th default that would basically be ("All PMO Projects" minus "Baseline")
If i was to write this in SQL it would look like "PMO Projects" != PRJ* (all the Projects start with PRJ). But wildcards don't work on our Jira without certain plug ins. (also tried ?,!,~ with various syntax)
How would I write this as a calculated member using aggregation? I tried this:
Aggregate(
[PMO Projects].[All PMO Projects] - [0002 : Baseline]
But then it tells me to create a calculated measure instead and when i try that it gives syntax errors.
Thanks in advance!
Rob
Register now
