Calculated custom field script is not working
Software Asset Management September 15, 2016
I am trying to create Scripted Field with below script.
import com.atlassian.jira.component.ComponentAccessor;
import com.atlassian.jira.issue.CustomFieldManager;
import com.atlassian.jira.issue.Issue as Issue;
import com.atlassian.jira.issue.fields.CustomField;
def CustomFieldManager customFieldManager = ComponentAccessor.getCustomFieldManager();
// gets a reference to the desired custom field
def CustomField cf = customFieldManager.getCustomFieldObjectByName("Time Criticality");
def CustomField cf1 = customFieldManager.getCustomFieldObjectByName("User Business Value");
def CustomField cf2 = customFieldManager.getCustomFieldObjectByName("Risk/Opportunity Value");
// retrieves the custom field value object from the issue
def Object cfv = Issue.getCustomFieldValue(cf).toString();
def Object cfv1 = Issue.getCustomFieldValue(cf1).toString();
def Object cfv2 = Issue.getCustomFieldValue(cf2).toString();
return cfv + cfv1 + cfv2;
Above script does not have any compile errors but when executing the same, I am getting below error.
groovy.lang.MissingMethodException: No signature of method: static com.atlassian.jira.issue.Issue.getCustomFieldValue() is applicable for argument types: (com.atlassian.jira.issue.fields.CustomFieldImpl) values: [Time criticality]
Can someone please help me in above script?
Thanos Batagiannis [Adaptavist]
September 15, 2016
remove line
and use issue instead of Issue
regards
Software Asset Management September 16, 2016
Hello Thanos,
Thanks for quick response. I made the suggested changes and getting java null pointer exception error.
//import com.atlassian.jira.issue.Issue as Issue;
def CustomField cf = customFieldManager.getCustomFieldObjectByName("customfield_21620");
def CustomField cf1 = customFieldManager.getCustomFieldObjectByName("customfield_21621");
def CustomField cf2 = customFieldManager.getCustomFieldObjectByName("customfield_21622");
def Object cfv = issue.getCustomFieldValue(cf).toString();
def Object cfv1 = issue.getCustomFieldValue(cf1).toString();
def Object cfv2 = issue.getCustomFieldValue(cf2).toString();
Can you please help me again?
September 16, 2016
try
def cf = customFieldManager.getCustomFieldObjectByName("Time Criticality")
def cf1 = customFieldManager.getCustomFieldObjectByName("User Business Value")
def cf2 = customFieldManager.getCustomFieldObjectByName("Risk/Opportunity Value")
def cfv = issue.getCustomFieldValue(cf)?.toString()
def cfv1 = issue.getCustomFieldValue(cf1)?.toString()
def cfv2 = issue.getCustomFieldValue(cf2)?.toString()
Software Asset Management September 21, 2016
Thanks Thanos for providing above script.
Script is working fine without errors but output is not correct. I am getting $value.longValue() as output.
Can you please suggest?
JamieA
September 25, 2016
You must be using the number template. Why are you converting them to strings?
Software Asset Management September 25, 2016
I am using Select List type fields. Since they are treated as objects I am trying to convert them into string. Correct me if I am wrong
JamieA
September 26, 2016
Fine but are the values actually numbers? Or are you trying to concatenate their values?
If they are numbers do something like:
return (cfv as Long) + (cfv1 as Long) + (cfv2 as Long)
