Call external REST API from workflow transition
Andrew Downs
We have a custom web api that I have configured as a web hook in Jira, what I need to do is call this API and pass specific parameters from the Service Desk call to it in a specific workflow step.
For example on the Jira call we have the following custom fields:
Full Name: John Doe
First Name: John
Surname: Doe
ID Number: 1234567890
Office Number etc
What I would like to do is call the web hook passing the following information:
https://<apiserver>/api/Employee/{"fullName": "John Doe", "firstName": "John", "lastName": "Doe", "identificationNumber": "1234567890"}
Is this possible to do from within Jira Groovy script or workflow process?
Alexey Matveev
May 10, 2018
It is possible to call external REST API from a groovy script. You can find an example here:
https://community.atlassian.com/t5/Answers-Developer-Questions/Making-a-REST-call-using-script-runner/qaq-p/576712
Or you can use the Jira web hook functionality to get the same result. You can not change the default json sent by the Jira web hook. But you can change the Rest Method in the external application. You can read more about Jira webhooks here:
https://developer.atlassian.com/server/jira/platform/webhooks/
Andrew Downs
May 11, 2018 edited
Hi Alexey,
Ok, so I have managed to piece together something, but am battling when trying to format the JSON.
This is what I have so far:
import groovy.json.JsonSlurper;
import groovy.json.StreamingJsonBuilder;
import com.atlassian.jira.ComponentManager;
import com.atlassian.jira.issue.CustomFieldManager;
import com.atlassian.jira.issue.fields.CustomField;
import com.atlassian.jira.issue.IssueManager;
import com.atlassian.jira.component.ComponentAccessor;
import com.atlassian.jira.issue.Issue;
import org.apache.commons.codec.binary.Base64;
import groovyx.net.http.HTTPBuilder
import static groovyx.net.http.ContentType.*
import groovyx.net.http.ContentType
import static groovyx.net.http.Method.*
import net.sf.json.groovy.JsonSlurper
import groovy.json.JsonOutput
// Define Required Component Access
def issueManager = ComponentAccessor.getIssueManager()
// Get Issue ID that contains the Data
Issue issue = issueManager.getIssueObject( "SSD-18222" );
// Get field values
def fullName = customFieldManager.getCustomFieldObjectByName("Full Name");
def fullNameValue = issue.getCustomFieldValue(fullName);
//def firstName = customFieldManager.getCustomFieldObjectByName("Firstname");
//def firstNameValue = issue.getCustomFieldValue(firstName);
def firstNameValue = "Jane"
def lastName = customFieldManager.getCustomFieldObjectByName("Surname");
def lastNameValue = issue.getCustomFieldValue(lastName);
//def officeNumber = customFieldManager.getCustomFieldObjectByName("Office Number");
//def officeNumberValue = issue.getCustomFieldValue(officeNumber);
def officeNumberValue = "+27115234020"
def mobileNumber = customFieldManager.getCustomFieldObjectByName("Cell Phone Number");
def mobileNumberValue = issue.getCustomFieldValue(mobileNumber);
//def faxNumber = customFieldManager.getCustomFieldObjectByName("Office Number");
//def faxNumberValue = issue.getCustomFieldValue(faxNumber);
def title = customFieldManager.getCustomFieldObjectByName("Job Title");
def titleValue = issue.getCustomFieldValue(title);
def department = customFieldManager.getCustomFieldObjectByName("Department");
def departmentValue = issue.getCustomFieldValue(department);
def siteName = customFieldManager.getCustomFieldObjectByName("Site Code");
def siteNameValue = issue.getCustomFieldValue(siteName);
def idNumber = customFieldManager.getCustomFieldObjectByName("ID Number");
def idNumberValue = issue.getCustomFieldValue(idNumber);
//def passportNumber = customFieldManager.getCustomFieldObjectByName("Passport Number");
//def passportNumberValue = issue.getCustomFieldValue(passportNumber);
//def birthdate = customFieldManager.getCustomFieldObjectByName("Birthday");
//def birthdateValue = issue.getCustomFieldValue(birthdate);
// Define JSON
def ContainerPath = "LDAP://OU=BU3,OU=BU2,OU=BU1,OU=Employees,OU=contoso,DC=contoso,DC=com"
def jsonBody = """{
    "parentContainerPath": {ContainerPath},
    "firstName": firstNameValue,
    "lastName": lastNameValue,
    "telehpone": officeNumberValue,
    "mobile": mobileNumberValue,
    "title": titleValue,
    "department": departmentValue,
    "siteName": siteNameValue,
    "identificationNumber": idNumberValue,
    "passportNumber": idNumberValue,
    "birthDate": "birthday"
return jsonBody
// Define Web API to post to
def baseURL = "http://<server>:8090/api/Employees";
// Establish Connection and post data
URL url = new URL(baseURL);
//URLConnection connection = url.openConnection();
HttpURLConnection connection = url.openConnection() as HttpURLConnection;
connection.requestMethod = "POST"
connection.doOutput = true
connection.setRequestProperty("Content-Type", "application/json;charset=UTF-8")
connection.outputStream
connection.outputStream.withWriter("UTF-8") { new StreamingJsonBuilder(it, jsonBody) }
connection.connect();
log.info ("URL="+url+"Status="+connection.getResponseCode() as String)
The problem is with the jsonBody, if I run it I get the following returned:
{ "parentContainerPath": {ContainerPath}, "firstName": firstNameValue, "lastName": lastNameValue, "telehpone": officeNumberValue, "mobile": mobileNumberValue, "title": titleValue, "department": departmentValue, "siteName": siteNameValue, "identificationNumber": idNumberValue, "passportNumber": idNumberValue, "birthDate": "birthday" }
It does not seem to be pulling through the values defined. Is there something that I am missing?
if I format the jsonBody object as follows:
def jsonBody = [
The JSON appears to be malformed and I get an error when posting the web API.
Regards
Alexey Matveev
May 11, 2018
That is right you should concatenate your variable, like this
def jsonBody = "{
    \"parentContainerPath\":" +  {ContainerPath} + "," +
    "\"firstName\":" + firstNameValue
Andrew Downs May 11, 2018 edited
Ok, formatted as follows:
def jsonBody = "{
    \"parentContainerPath\":" +  ContainerPath + "," +
    \"firstName\":" + firstNameValue + "," +
    \"lastName\":" + lastNameValue + "," +
    \"telehpone\":" + officeNumberValue + "," +
    \"mobile\":" + mobileNumberValue + "," +
    \"title\":" + titleValue + "," +
    \"department\":" + departmentValue + "," +
    \"siteName\":" + siteNameValue + "," +
    \"identificationNumber\":" + idNumberValue + "," +
    \"passportNumber\":" + idNumberValue + "," +
    \"birthDate\":" + birthday"
But now getting the below error:
org.codehaus.groovy.control.MultipleCompilationErrorsException: startup failed: Script44.groovy: 59: expecting anything but ''\n''; got it anyway @ line 59, column 18. def jsonBody = "{ ^ 1 error
Andrew Downs
def jsonBody = "{
Andrew Downs May 31, 2018
Managed to get it working as required.
Swarna Radha
Hi Andrew,
I have got an error '\n''; got it anyway.. How did you solve the issue?
Swarna
Rodolfo So April 7, 2021
Hi @Andrew Downs
How do you resolved the issue?
Andrew Downs May 28, 2018
String is formatted as follows:
def jsonBody = "{
Andrew Downs
Thank you Alexey, I will have a look and see what I can do with.
