Call to API /rest/api/2/reindex/issue returns 404 error
rhochteil April 12, 2019
I am getting an error 404 trying to use the reindex api. Please show me a JAVA example of the call.
POST /rest/api/2/reindex/issue
I have tried with ISSUE_ID from previous query......
jsonStr = "{\"issueId\": \"" + rs.getString("ISSUE_ID") + "\"}";
response = client.jiraConn.Post("/rest/api/latest/reindex/issue", jsonStr.getBytes(), headers);
and
/rest/api/latest/reindex/issue/" + rs.getString("ISSUE_ID")
Both return error 404
But the jira issue id does exist.
rhochteil April 14, 2019
I solved my problem.
http://My.Domain/jira/rest/api/latest/reindex/issue?issueId=339331
I forgot to put the /jira in front of the /rest/api/...
Thank you to everyone who tried to help me.
Robin
Harshada Gothankar
October 3, 2019
I am getting 404 for the below API. How do I fix it? I need this API to integrate with Japsersoft tool.
https://arterra.atlassian.net/rest/api/issues/?jql=project%20%3D%20%22CHAR%22%20AND%20component%20%3D%20Order_NotShipped
Thanks in Advance
Alexey Matveev
April 13, 2019
Try to use:
and issueId is a parameter and you send it as the payload. It should be like this
rest/api/2/reindex/issue?issueId=12342
Hi. Thank you for your response but I am using Java code not the URL line.
I have tried these 4 ways with a continuous 404 result
response = client.jiraConn.Post("/rest/api/2/reindex/issue/issueId:339331", "", headers);
response = client.jiraConn.Post("/rest/api/latest/reindex/issue", "{\"issueId\":\"339331\"}", headers);
response = client.jiraConn.Post("/rest/api/latest/reindex/issue", "{\"issueId\": \"CPQCS-5523\"}", headers);
response = client.jiraConn.Post("/rest/api/2/reindex/issue?issueId=339331", "", headers);
Bastian Stehmann
But you will have to tell your connection which server it should connect to. Do you do that somewhere?
yes
rhochteil April 14, 2019 edited
http://My.Domain/rest/api/latest/reindex/issue?issueId=339331
<!DOCTYPE HTML PUBLIC '-//IETF//DTD HTML 2.0//EN'><html><head><title>404 Not Found</title></head><body><h1>Not Found</h1><p>The requested URL /rest/api/latest/reindex/issue was not found.</p></body></html>
Bastian Stehmann
Hi @rhochteil ,
It seems that you missed the host name of the URL, try http://jiradomain.com/rest/...
And replace jiradomain.com with domain and port where your Jira is running.
