I am trying to set up the following Workflow in Automation for JIRA.
When the value changes for the Sprint field
Then add the sprint's end date to the field "Due date"
Here is the custom field.
"customfield_10301":[
"com.atlassian.greenhopper.service.sprint.Sprint@487c3460[id=592,rapidViewId=289,state=ACTIVE,name=Ca$htime,goal=,startDate=2017-01-09T19:53:52.703Z,endDate=2019-01-21T02:53:00.000Z,completeDate=<null>,sequence=592]"],
I was thinking it would work if I tried
{{issue.customfield_10301.endDate}}
but that did not work.
Hey @Chris Fadell did you ever get an answer to this? I am in quest of the same thing. Despite the field showing up as that long string in the API, all I get when I try to output the field in a comment is the sprint name, so I don't know that the string functions would even work here.
