If I select a Project, go to the Components page and click Manage Components I get a screen which allows me to change the Component Lead for the various components. I don't see a Tools menu to do a Bulk Edit the usual way so I'm wondering if anyone knows how I can avoid having to change the Component Leads individually?
There is not bulk edit option. If it is something that you do regularly, you might want to write a script that does it.
I thought as much. I can't find it because it isn't there. At least I know I can stop looking now, thanks.
