×Is it possible to create tooltips within dashboards?
Have you looked at the Text gadget?
Dear Jack, thanks for the prompt reply:-). This is my first post, so I am really thrilled how fast this is working;-)
Do you mean this one ?
I rather thought of a mouseover for specific gadgets, e.g. for the controller.
But the text gadget is at least an option. So thanks for the hint!
Co
That looks correct but TBH I rarely use the gadget. There isn’t a mouse over solution OOTB.
You might also check the Marketplace as there are quite a few addons but I don’t have any direct experience here.
Thanks to you, I am quite happy now with the text gadget to display hints and links:-)
Btw: Is there a reason why there is no 'project shortcuts' option in the left-side menu-bar? Similar to other Jira boards?
That would also help a lot. It is kind of irritating that you have it on Backlog/Kanban, but not in Dashboards.
Kind regards
Co
Are you looking to adding custom details/text to a tooltip?
I'm asking because there are good apps in the marketplace that has a good tooltip in their gadgets.
I would like to have tooltips in dashboards.
I am dreaming of adding custom text (explanation, hints, etc.) to a specific gadget, If you do a mouseover on this gadget, the text will appear. The way it works with workflow status or transitions.
