Is there a possibility to build global templates in proforma? Or only per project?
I have no template section at --> apps --> proforma --> forms.
thx for your help!
Hi @Thomi
Based on the instructions it looks like you have to create a template and then apply them to the projects manually.
Hi @Thomi and @Fabian Lim 👋
That's right. At the moment there isn't an option to create global templates. This feature has been requested a number of times and I've added a link to this post to the product board.
I can't say if or when this will be developed, but we appreciate your suggestion!
Thanx folks for your anwers. Yes, this would be more than just helpful! Hopefully, one day... :-)
Kind regards
thomi
