Can I combine two dimensions into one measure
James Weaver September 4, 2018
I'm trying to create a measure that will present a number of scenarios from 2 separate dimensions...
I'd like to show the number of issues created that satisfy the following scenarios:
1) Environment List = "OB - PROD" & Checklist = "5) OBPROD"
2) Environment List = "OB - PROD"
3) Checklist = "5) OBPROD"
For scenarios 2 and 3 it doesn't matter what the other dimensions value is as long as it matches the value above.
Is there a way to show this figure in one custom measure? I am using the "Issues created count" measure to count the issues.
