  • Community
  • Q&A
  • Jira
  • Questions
  • Can I configure Links between Issue to just allow a certain Issue Type for that particular link?
a.haaken
I Want to restrict the useage of links bewteen Issues, s.t. a certain type can just be connected to another type by a certain link. Or lets turn it around, I want to restrcit the issuetypes for a ceratin link.
e.g.
Define a Link ("Re realizes Story"), which just allows issuetype "requirement" on the outgoing side and "UserStory" on the incoming Side.
Is that pssible in any way?
JamieA
April 19, 2012
You can't do it natively, but you could do with either or both of javascript and a validator... to make it work properly you might need to disable the issue link operation, so users can only create a link on edit or transition.
If you don't do that it's not possible to validate the link.
a.haaken
Well, that s too bad.. Is there Plugin out there, which allows Custom Fields to be defined as Issue-Link?
Renjith Pillai
April 22, 2012
Is this of any use? https://plugins.atlassian.com/35740
But Jira 5 support is doubtful.
a.haaken
It would be great, if it works with Jira 5.. but the progress seems to be poor..:/
