×I have JIRA 6.0.8 and have tried putting the following script in my custom field (free text unlimited) called "Test Script". I only want the field to display when the custom radio button field "Auto/Manual" is set to "Manual".
I entered the script in the description (Custom Fields / Edit / Description)
10900 is the Auto/Manual field, 11300 is the Test Script field
I am using Chrome. Haven't tried any other browsers.
<script type="text/javascript">
AJS.$(document).bind('dialogContentReady', function(event, dialog) {
field = document.getElementById('customfield_10900');
if (field) {
target = document.getElementById('customfield_11300').parentNode;
// Hide the Test Script field if Auto/Manual doesn't equal Manual
if (field.value != 'Manual')target.style.display='none';
field.onchange=function() {
if (this.value == 'Manual') {
target.style.display = ";
target.value="Specify the name (or ID) of the test script where the sub-test is to be manually tested.";
} else {
</script>
I have the similar issue. I cannot use Bheaviours plugin as it is not supported in JIRA 6.2.3.
Can someone help??
