×We currently have gitlab for JIRA plugin installed. Integration with one instance of gitlab has already been enabled and is working well. Would like to integrate another instance of gitlab as well. Is that supported?
Hi Padma -
Using the Git Integration for Jira app you can connect any number of GitLab servers (including GitLab.com and non-GitLab services like GitHub, AWS CodeCommit, etc).
Adam
@Padma Prakash - if you're all set here - would you mark the question as answered? Thanks!
Hi @Adam Wride ,
Please confirm is it possible to integrate one Jira with multiple Gitlab instances without any plugins?
I already one Gitlab instance using below document and want to integrate one more Gitlab instance
https://about.gitlab.com/blog/2021/04/12/gitlab-jira-integration-selfmanaged/
Thanks in advance
@Balvant Biradar - we support the Git Integration for Jira app sold on the Atlassian Marketplace. You can certainly integrate with multiple GitLab instances but it does require installing our app/plugin. The documentation you refer to is GitLab's integration with Jira. You can contact GitLab if you have questions about that approach.
If you have additional questions about our product, contact us at support@bigbrassband.com
Adam
