This question is in reference to Atlassian Documentation: Learn stages and skills
JIRA Portfolio Cloud seems to apply the same stages/skills to all JIRA issue within a plan. Is there any way to modify the stages or skills on a per issue basis? For example, I might want to add the skills Javascript Development and Database Development to the Implementation stage. While those are both common skills, not every issue requires both. If I have an issue that does not involve Javascript is there some way to remove it from that ticket so scheduling is not dependent on a team member with Javascript skills?
I should mention this question is for a Kanban project not a Scrum project.
Hi Doug,
You can manage the skills necessary for each issue by changing the estimate for that skill on said issue.
Allard
Allard,
Thanks for your help! I was looking for the stages and skills on the JIRA issue itself and didn't even think to expand the Estimate column on the Scope view within portfolio. That works!
Doug
@Doug Couvillion, glad I could help you.
If this answers your question, could you please mark the answer as correct? Thanks!
It's been 2 years and Atlassian still hasn't updated their documentation with how to assign a specific skill to a specific issue from within Portfolio.
Read the story
