Can I retrieve data from Jira Database using sql instead of jql ?
Jurgen Sërbo May 26, 2017 edited
I want to do something like this to make reports easy for me and for my unit.
Nic Brough -Adaptavist-
May 26, 2017
No, you don't.  Seriously, that is NOT going to "make reports easy".
To perform a full search for JIRA issues matching something, you could have to join the main issue table up to 30 times, and via multi-layered joins.  Even a search for a simple custom field is 3 or 4 joins, depending on the type.
SQL is the worst way to do it.
Have a look in the marketplace for reporting add-ons.  And maybe tell us what report(s) you are looking for as we might be able to point you at something better.
Jurgen Sërbo May 27, 2017 edited
May 27, 2017
Tell them they're wrong.  You have the support of all of us who've looked at the database!
Jurgen Sërbo May 29, 2017
Please, can you suggest me an add-on to use for this porpuse.
Thanx :D
May 29, 2017
You'll want one that understands the JIRA database properly.  There's quite a few around, but I'd lean towards EazyBI and Arsenale's Dataplane.  They're very different beasts, so it's worth a look at both to compare them for your needs, and any others you find in the marketplace.
Jurgen Sërbo June 13, 2017
Hey there,
Please can u say to me if it is a good way to connect Jira DB with Access, for reports to come easy ?
Thanx
June 13, 2017
No.  Absolutely not.
Access is not a proper database and it's pretty much impossible to use it as a back-end for JIRA.  Even if you could get it to work (you won't), you are totally unsupported and won't be able to upgrade it.
If you mean you want to keep JIRA on a proper supported database and then try to use Access for reporting, you'll still be trying to use SQL to read JIRA, which we've already discussed as being a terrible thing to do and never "easy".
Jurgen Sërbo June 13, 2017 edited
I asked this, because someone here has made some queries in access and this is the way that we report LogWorked and the add-on we use for time tracking is : https://marketplace.atlassian.com/plugins/org.everit.jira.timetracker.plugin/server/overview
June 13, 2017
Your user will have to download copies of the work logged data to mangle in Access.
By far the best way to do that is to use the REST API to pull out the data they want, then write something to change it into the shape you need.Or use the functions in the add-on you have?
Every time i make the timetracker report, i export all the fields in excel and then copy them in the access table and re-run the query to track the time worked.
June 13, 2017
Ok, that's another way to do it.
Although I would question why your add-on doesn't do the report you want.
Becuase :
Senior = Grade 1
Specialist = Grade 2
Junior = Grade 3
and if a seniour user has loged 43210 sec we calculate this : 43210/60/60/8/grade of the user.
June 13, 2017
Tempo's folio add-on does that doer of thing.
So sthm is clear, in Jira almost everything is done using add-ons..
Am I right ?
June 13, 2017
No.  Projects, issues, fields, workflows, time logs, comments, etc - everything that is related to "issue tracking" is done in JIRA
When the main product can't meet your specific needs because it's a generalised application, then you start looking at add-ons
Ok thanks for your help.. :)
Learn more
