I've got a really old, misbehaving JIRA instance being used for "production" quality work, so it has to stay up and have defined change windows/policies. I'm trying to keep the plugins up-to-date (at least), but often, I have to restart the service after an update even if the plugin updater doesn't recommend/require it.
I've scheduled JIRA restarts before using the `at` command in my linux distro. I'd like to schedule a plugin update and a restart together using any other bash/shell commands necessary.
Is this possible?
Also, is there any comprehensive documentation on CLI options for administrators? I couldn't find any.
I would create a script which downloads newest version of plugins (*.jar) which you use. Then - when jira restarts - copy those JARs to [jira-home]/plugins/installed-plugins directory.
Is it that easy? The plugins are competely self-contained JARs? There's no scripted upgrade that happens as part of the plugin manager upgrading it?
Yes. If scripts are needed - they will be executed upon jira startup. If you will eventually exeprience problems try adding to script to delete plugin cache directory, but I'm quite sure it will be ok even without it.
