Can I use Java in a Gadget Plugin?
Maja Stach June 3, 2013
I'm writing a gadget for Jira and since I'm not really good at Javascript I was wondering if it is possible to refer to data in a .java file. It would make handling information so much easier for me.
I'm thinking about writing code similar to a report.
Is that possible?
Jobin Kuruvilla [Adaptavist]
June 3, 2013
Data handling can be done in Java, in a rest plugin. The UI rendering will still be javascript.
Timothy
June 3, 2013
Lots of Javascript!
Maja Stach June 4, 2013
So, do I need to add a rest pluginmodule to my plugin?
and how do I access the code?
RambanamP
June 4, 2013
check the following doc to develop rest plugin
https://developer.atlassian.com/display/DOCS/REST+Plugin+Module
