Can System Fields be set as to Visible even when empty?
Janet Coffey
I know I can set custom fields to be visible even when empty.  Can I do the same thing for System Fields?
Nicketa
Hello @Janet Coffey ,
In the new Jira versions, you'll get option to keep a field visible even when it is empty.
Can do it from screen configuration view.
System fields can always be hidden using field configuration.
BR,
Nicketa
Aaron Pavez _ServiceRocket_
Hi @Janet Coffey
By default the standard fields (Description, Status, Priority) are visible when empty.
Which one you don't see when empty?
Hav you checked this?
2024-11-08 15_21_49-Configure issue - CaseSF - Issue types - Jira — Mozilla Firefox.jpg
Under configure fields (Cog at the bottom right) you can add the standards fields there.
Regards
Aaron
Janet Coffey
I'm trying to get the "Linked Issues" field to appear on all project Edit screens.  Are you looking at Data Center Jira or Cloud Jira?
Janet Coffey
Sorry it's on the View screen I'd like it to appear on.
Matt Doar _Adaptavist_
That info is in its own subsection of an issue, so should appear by default on View screens, unless Linking has been disabled for the whole instance
Linked issues won't show by default when empty. It will only show when there is a linked issue.
Regards
Like Nicketa likes this
Janet Coffey
Aaron,
That's the behavior I'm seeing.  Thank you
Janet Coffey
SERVER
VERSION
9.12.14
