Can a notification be created for a certain issue type
Jen-Qology
Deleted user September 4, 2015
Yes you can, there are several ways to accomplish this, I can suggest:
  • Associate your desired issue type to a particular workflow and for that workflow, update it's post-function events to use your desired email notifications.
  • For an existing workflow, you may add a post-function "Send Email" using the ScriptRunner plugin.
Both suggestions have a robust documentation so you will not have a hard time.
https://confluence.atlassian.com/jira/creating-a-notification-scheme-185729542.html
https://scriptrunner.adaptavist.com/latest/jira/quickstart.html
Paulo Hennig
September 4, 2015
Hello Jen,
I would advice you to use the Automation plugin as a easy way to accomplish this goal. Basically you can set a filter if a created issue match a specific issue type, then send a notification
Read the story
