Can any body Help me to write java script in velocity file?
Nageswarara Rao
Hi
I coded javascript in velocity file as like as follows , but i am getting errors
please help me to solve this problem
My code:
<script>
#[[ $(document).ready(userDetails(){
<table align=center bgcolor="bbbbbb" border="1" cellpadding="0" cellspacing="0" width=100%>
<tr bgcolor="#f0f0f0">
<td valign="center">
<table bgcolor ="#fffff0" border="0" cellpadding="3" cellspacing="1" width="100%" class="grid">
<tr valign="top" bgcolor="#f0f0f0">
<td><b>$action.getText("bulkuserdeactivation.name")</b></td>
</tr>
#foreach ($element in $action.getAllUsers())
#if($document.form.userNameContains.value == ($element.getName()))
<tr >
<td><input type="checkbox" name="checkbox" align="center">$element.getName()</td>
</tr>
#end
#end
</table>
</td>
</tr>
</table>
</script>
Andy Brook [Plugin People]
December 12, 2012
Yes, that , but this still isn't going to work I think. It looks like you're mixing server side and client side contexts. Anything beginning with # is Velocity markup that is converted to 'html' on loading (assuming this is an embedded script), at that time it does not have access to the 'document', so whilst:
will work fine,
will not, as the 'document' only exists in the client browser. Perhaps you didn't mean it to be Velocity and meant it to just be javascript, if so I think you just need to change the
#if ($document.
for
if (document.
Mizan
December 12, 2012
Use AJS.$ instead of $ in your script .
