×Reason: It will simplify any complicated project.
The workflow for an issue is configurable by issue type - if you open up a "workflow scheme", you'll see it lists which issue types use which workflows in the project you apply the scheme to.
So, no, Epics in a project can't have different workflows, but yes, you can have Epics, Stories, Bugs, Tasks etc all use different workflows in the project.
Thanks, I have another quick question. I created a demo project. Inside this demo project I created 2 epics, 1 story and 1 task; and tried to change workflow for epics, story and task. But I am still getting same workflow for all (epics, story and task). Any suggestions or link to assign different workflow to story, task and epics inside a project?
Have you set up and applied a different workflow scheme?
Hi @Priyanka Goenka,
The answer is no, different epics within a project cannot have different workflows.
Unlock your potential and learn how to use Jira Product Discovery to your advantage. You’ll have the expertise to revolutionize ideas and insights, roadmapping, engage and align teams and stakeholders, and deliver the best solutions—faster. Enroll today!
Start Learning
