Can i bulk create (CSV) recurring sub-tasks into a parent by adding multiple parent ids in a col?
james.monro August 5, 2020
I want to recreate a series of sub-tasks. e.g for each month, 5 countries need to do the same activity.
I have create the months as epics, the counties as tasks within the epic, and now i wan to bulk create the activities in each task. Can i do this by adding multiple parent ids (i.e. the jira for each country each month) into a single column on the CSV, separated by a comma?
John Funk
Hi James,
I would use some type of Automation to create the tasks. The Automation For Jira add-on can do that with the Scheduled trigger or you could base it on each task as it gets closed creating a new one for the next month.
james.monro August 7, 2020
Thanks John. It wouldnt quite work for what i needed. i did a huge round of bulk uploads. not ideal but...
Like • John Funk likes this
John Funk
Can you share why the automation didn't quite work? Maybe we can work something out that would help with something similar in the future.  :-)
