Users are unable to add files via Drag and Drop plugin after the latest upgrade to v3.0. The latest release added a "select files" option. This option does not appear to work.
Niether the Drag and Drop or 'select files' option works for users in IE or Safari.
Has anyone else run into this issue?
Hi Jeanne,
In terms of IE, you can definately not use drag and drop. I faced the same problem. I have not tested it with Safari. For that functionality, you will have to use another browser.
