Hi, I did some changes in the field configuration schemes. Afterwards I tried to create an issue. It does not work, no error messages, just the waiting symbol. Would a maybe a re-index help? (my version is 5.0)
Few places to check for logged errors, depending on your installation, e.g.
I have seen similar issues before, and found some errors in logs, turned out to be plugin/custom field related. Of course, your case might be different, so looking at the logs will be the first step.
check the atlassian-jira.log in the log folder of your home directory
Alternatively check with tools like firebug if sth. pops up
And when you mention no error messages, is this from the logs?
