Can not import amd Module: No test/jira
Deleted user December 21, 2018
Hi!
I tried edit tutorial code from Atlassian (DASHBOARD-TUTORIAL), but when I change "amd module" in atlassian-plugin.xml and javascript file on my namespace, I get only error
"Unknown error occurred initializing this gadget."
console say:
"Can not import amd Module test/jira gadget with id '10102': No test/jira Error: No test/jira"
My atlassian-plugin.xml:
<atlassian-plugin key="${atlassian.plugin.key}" name="${project.name}" plugins-version="2">
<plugin-info>
<description>${project.description}</description>
<version>${project.version}</version>
<vendor name="${project.organization.name}" url="${project.organization.url}" />
<param name="plugin-icon">images/pluginIcon.png</param>
<param name="plugin-logo">images/pluginLogo.png</param>
</plugin-info>
<!-- add our i18n resource -->
<resource type="i18n" name="i18n" location="dashboard-item-tutorial"/>
<!-- add our web resources -->
<web-resource key="dashboard-item-tutorial-resources" name="dashboard-item-tutorial Web Resources">
<dependency>com.atlassian.auiplugin:ajs</dependency>
<transformation extension="soy">
<transformer key="soyTransformer"/>
</transformation>
<resource type="download" name="dashboard-item-tutorial.css" location="/css/dashboard-item-tutorial.css"/>
<resource type="download" name="dashboard-item-tutorial.js" location="/js/dashboard-item-tutorial.js"/>
<resource type="download" name="images/" location="/images"/>
<resource type="download" location="soy/dashboard-item.soy" name="soy/dashboard-item.soy.js"/>
<resource type="soy" location="/soy/dashboard-item.soy" name="Dashboard.Item.Tutorial.Templates.Static"/>
<context>atl.dashboard</context>
<context>dashboard-item-tutorial</context>
</web-resource>
<dashboard-item key="new-dashboard-item"
i18n-name-key="com.example.plugins.tutorial.dashboard.item.title"
configurable="true">
<definition>
<title key="com.example.plugins.tutorial.dashboard.item.title"/>
<categories>
<category>Jira</category>
</categories>
<author>
<name>Author's name</name>
</author>
<thumbnail location="/download/resources/${atlassian.plugin.key}:dashboard-item-tutorial-resources/images/pluginLogo.png"/>
</definition>
<description key="com.example.plugins.tutorial.dashboard.item.description"/>
<resource name="view" type="soy" location=":dashboard-item-tutorial-resources/Dashboard.Item.Tutorial.Templates.Static"/>
<amd-module>test/jira</amd-module>
</dashboard-item>
</atlassian-plugin>
My JS script:
 define('test/jira', ['underscore', 'jquery', 'wrm/context-path'], function (_, $, contextPath) {
var DashboardItem = function (API) {
this.API = API;
this.issues = [];
* Called to render the view for a fully configured dashboard item.
* @param context The surrounding <div/> context that this items should render into.
* @param preferences The user preferences saved for this dashboard item (e.g. filter id, number of results...)
DashboardItem.prototype.render = function (context, preferences) {
this.API.showLoadingBar();
var $element = this.$element = $(context).find("#dynamic-content");
var self = this;
this.requestData().done(function (data) {
self.API.hideLoadingBar();
self.issues = data.issues;
if (self.issues === undefined || self.issues.length === 0) {
$element.empty().html(Dashboard.Item.Tutorial.Templates.Empty());
else {
$element.empty().html(Dashboard.Item.Tutorial.Templates.IssueList({issues: self.issues}));
self.API.resize();
$element.find(".submit").click(function (event) {
event.preventDefault();
self.render(element, preferences);
this.API.once("afterRender", this.API.resize);
DashboardItem.prototype.requestData = function () {
return $.ajax({
method: "GET",
url: contextPath() + "/rest/api/2/search?jql=due<=3d"
return DashboardItem;
2 accepted
Nir Haimov
November 14, 2019
@[deleted]
Found out that for me it was just that I missed to add my JS module to the download resources.
I am familiar with the version in pom.xml and caching thing :)
Good to know you figured that out and solved your issue too.
Nir Haimov
November 14, 2019
Hi @[deleted]
Have you find any solution for this?
I just got into the same problem, actually i created 3 gadgets already and they work fine, but now the forth giving the exact same error as you had.
Deleted user November 14, 2019
Hi @Nir Haimov
In my case, answer was really simple:
Jira is dump.
JavaScript files are store in browser cache, so if I don't change plugin version in pom file (this force browser to recreate JavaScript file), dashboard item will use cached version. Another solution is use incognito mode in browser (in my case, it was best solution).
Glib April 25, 2023
Hi @Nir Haimov
Have you found the solution for the gadgets not loading?
Getting the same error intermittently
Can not import amd Module dashboard-items/scenario-count-dashboard-item gadget with id '10314': No dashboard-items/scenario-count-dashboard-item Error: No dashboard-items/scenario-count-dashboard-item
 The issue seems to be related to Chrome only as I cannot reproduce it other browsers.
