Can priorities be assigned different permissions?
Kelsey Collins February 19, 2015
I want to limit certain users or groups from marking an issue as critical or major so that management will be forced to log issues of higher priority.
Joe Pitt
No, not out of the box. they can set them or not. You may be able to do something with scripting, but then you'll need to maintain that when upgrading.
Kelsey Collins February 24, 2015
Thanks for the replies!
Udo Brand
February 19, 2015
Not really, but you could use a workaraound. Remove the field from edit screen, add to each status (except closed) a transition which goes back to original status, add a screen which contains priority and set a condition that only some roles/groups can use this transition.
Now you have what you want.
