Can programmatic limits be defined for gauges in eazyBI?
Matt DeLuco June 6, 2016
It seems the only way to set limits on gauge charts is by clicking the value beneath the chart and manually adding a limit.  Is there a way I can add a column to my report table upon which the gauge can base its limits?
For example, I'd like a gauge to show the number of issues closed in an epic against the total number of issues in said epic.
I've figured it out - the "measure" drop downs in the limits dialog.
Martins Vanags -eazyBI-
Hi Matt,
I am happy you figured it out by yourself.
Yes, you can pick a measure as a limit for gauge chart.
Please contact support@eazybi.com if you have further questions regarding eazyBI!
Martins Vanags / support@eazybi.com
Read the story
