This question is in reference to Atlassian Documentation: Define New Status or Steps in JIRA Workflow
I found similar questions in the past and answers, but still i don't get the difference between a step and a status
If someone can give me some examples or scenarios it might help clearing things up.
Hope you can help
Tnx
Shirley
A step is a point in a workflow. A status is mapped to the step and that is what users see.
Workflow steps are a fairly generic concept in the workflow world.
I think of Steps as being the structure of a workflow. As Steven says, things move from point to point in a workflow.
The status is the user-friendly display of a step - if you look closely at the options available, you'll see that while steps are fixed points, you can change the status associated with a step - it's a facade for the users.
different names for the same thing unless they are counting the transition as the 'step' because you can have multiple transitions from a status based on values of fields or user role/group
Thanks for the quick response Joe!
I found this discussion: https://answers.atlassian.com/questions/317465
Where there is some explanation, but i still don't get it =0
