Can standard JIRA Gadget support customized fields?
Victor Hsu February 22, 2013
Hi all,
Can standard JIRA Gadget support customized fields? for example, to support customized field in Two dimension table?
Adam Saint-Prix
February 22, 2013
Victor,
Out of the box that specific gadget will support the following types of custom fields: 'Group picker', 'Multi select', 'User picker', 'Select list' and 'Version picker.
Hi Adam,
thanks. I found barchart gadget can support customized field.
However, do you know any gadget which can give me Two Dimension statisics table only? I don't need the Chart here.
