I would like to be able to synchronize the incident states that I create through the option : Create linked issues
it's possible?
Thanks!!
You can do that by using some add-ons like.
Backbone Issue Sync for JIRa
Exocet
Issue Sync
-Ravi
The documentation indicates that: The linked issues are updated and people involved are notified when the issue or problem is resolved.
It looks like it can sync natively.
thanks!
Yes you can use JIRA Service Desk Automation to update linked issues, it is not be a sync but if you just want to update then yes it can work.
Register now
