×I have epic, story, task and sub-task auto created by automation rule. I can update the assignees field (people field) for sub task when they are changed at epic lvl. However if i try to update a custom field (A) that is of free text/dropdown, it doesnt get updated for sub task. Why is that so? Is that a limitation of jira automation rule?
Hi @Jar Lady
It should work; could you share how your rule looks at present, so we can advise further? :)
Ste
Hi Lady,
It should work the same. Can you share the rule? Are you updating both fields at the same time?
