×I'm building an email that sends ticket data to a user. It's a manual trigger and seems to be working just fine except for Issue Type. I can't get it to populate the Issue Type field in the table. Below you can see what I'm using for that field. I'm using the {{#lookupIssue}} function to get my tickets.
I've used: issueType.displayName, Issue Type, customfield_10106, customfield_10106.displayName, Type.name and many more.
I will put the entire code below
All
{{#lookupIssues}}{{/}}
Issue Type | Issue Key | Assignee | Title | Description | Story Points |
{{issueType.displayName}} | {{key}} | {{assignee}} | {{summary}} | {{description}} | {{Story Points.format("#")}} |
I guess everything I read online was true. It looks like the issueType field is a custom field and thus does not show up in a {{lookupIssues}} response. The way I got around this was to: branch off of the original ticket, use JQL as the "Type of Related Issues", make sure "Process all issues produced by this trigger in bulk" is checked, add table code to my email using the {{#issues}} code {{/}} to render the table.
Hope this helps someone.
Make sure you make the email recipient "Initiator" unless you have a group or specific person you want the email it to Always go to.
This smartvalue works on my Jira instance.
{{issueType.Name}}
I hope this works for you.
Nope. Strange how this is the only field that will not display.
@Marc - Devoteam This didn't work in the table but did work as a log action. Any thoughts on why? Could it be because it's part of a lookupIssue function?
I put the {{#lookupIssues}} function in a log action and it does not show the Issue Type field info.
Register Now
