Can't click on "Simplify workflow"?
Markus
We want to add 2 new status to our Kanban board. We go to "Board-> configure -> Columns" and then the Option "Simplify workflow" cant be clicked on, which means that we cant add new status (right?). We are only the adminis of the project.
Is there any way that we can resolve this issue?
Nic Brough -Adaptavist-
March 5, 2018
Only system and Jira admins can simplify a workflow.  Ask your admins to do that for you, then you should see the ability to add status.
Markus
HI thank you very much i will talk to them.
Marcela Junyent
November 1, 2018
Nic,
  Could you check this:
https://community.atlassian.com/t5/Jira-Software-questions/Who-can-Simplify-a-Workflow-through-the-board/qaq-p/894827#U929990
Because there is a documentation contradiction in this answer... Although it seems you are correct.
Regards
November 1, 2018
The documentation is wrong, it's Jira and System admins only, board admins can't do it.
Like • Marcela Junyent likes this
Marcela Junyent
November 1, 2018
thanks for your help.
Sloan
March 5, 2018
Hi @Markus
I am not sure if I understand right, can you please attach a Screenshot of your Board-Configuration and point to the unclickable link? Thanks. :)
By the way to add a status on a board it needs to be present in the workflow!
Regards
Niklas
Markus
Thank you for your answer i will look into it.
Steve Thornhill
March 5, 2018
Are you trying to add the 2 statuses into the workflow? Or do they exist and you are adding to the board?
For the first, update the workflow in the main admin->issues->workflows tab
For the second, add 2 extra columns, rename them as necessary and map the statuses to those columns.
Markus
Thank you.
Help us plant more trees
