Can't edit draw.io diagrams
Deleted user September 11, 2019
Hi
I can view draw.io diagrams in jira task but can't edit them. When I click edit button, it just shows draw.io icon and then nothing happens. It throws following errors in the browser console.
Uncaught SyntaxError: Unexpected token )
Access to fetch at 'https://mgas.prod.public.atl-paas.net/v1/event' from origin 'https://xyz.atlassian.net' has been blocked by CORS policy: Request header field x-atlassian-mau-ignore is not allowed by Access-Control-Allow-Headers in preflight response.
Marija Radovic
​Could you repeat all the steps in Incognito mode and check if it is working, please?
Incognito mode should be cache and browser extension free so it is good for testing. Do you have edit permission?
P.S you are using Jira Cloud? Just to be sure.
Marija
draw.io support
Hi Marija
It's not working in Incognito mode too.
I have created those diagrams and edited them many times in the past. Yes, I have edit permission.
Yes, we are using jira cloud. Our account is on atlassian.net
Marija Radovic
September 12, 2019
Thanks for the reply.
Could you tell me:
* what draw.io version you use (you can find it under Settings > Apps > Manage apps > expand draw.io)
* do you have editing issue with all diagrams or with some of them?
Marija
Deleted user September 12, 2019
We are using version 1.2.14-AC.
I and my other team members also have issue in editing all diagrams.
David Benson [draw.io]
September 12, 2019
Could you try updating to the latest plugin version please?
Latest version is paid. Have you stopped supporting free version?
September 12, 2019
The free version is a fixed code release that we cannot update. There will come a point when the Atlassian APIs change and our API calls are invalid. It's possible the last Jira Cloud release deprecated an API that codebase used.
If you don't want to pay you can download the attachment, edit it in www.draw.io and re-upload the changed attachment.
Deleted user September 17, 2019
After upgrading the plugin to the latest version, it is working fine. Thanks for your help.
