Can't edit the reporter field on a project
Leo
A lot of user from our space, can't edit the reporter filed on the ticket of an specific project, even though I and other users are in the administrators group, we can't edit the field.
7 votes
Elifcan Cakmak
May 7, 2019
Did you check who has the permission to modify reporter on your project?
Also reporter field should be present on edit screen, too.
Regards.
Leo
Yes, apparently no one can, it's really weird since I can do that in other projects but not even the one that created the project can, is like some kind of bug.
Nic Brough -Adaptavist-
May 7, 2019
But who has the project permission for modify reporter?  Can you check the permission shown for that project as @Elifcan Cakmak has shown?
Leo
From what I was told just now, everyone that has administrator group could do it two weeks ago but now, no one can. You can see that in here Permissions.jpg
Elifcan Cakmak
May 7, 2019
Roles are groups are different things. In your project, project role administrators has the permission to modify reporter. You can see who are in this role on People tab on the left.
Also as I said earlier, reporter field should be on the edit screen of your project. Maybe someone removed it since then?
Regards.
Like # people like this
Leo
Hi, I was trying to add the reporter field in the edit screen, but it's still not working
Leo
May 8, 2019
Ok, it's on screen, so the next two questions are:
  • Are you using that screen for issue edit?
  • Do you have the project rights to edit the reporter?  (Are you in one of the two roles in the project that have the right in your screenshot?)
Leo
Yesterday, I tried to modify the reporter field when I added all the roles in the project, and it didn't work, but I changed the "Edit Screen" as well and even yesterday didn't work, today it worked, perfectly. Thank you for you help to both of you.
Jon Mills
This helped me too - the edit screen didn't have 'reporter' field in it, even though it shows on the screen.  Adding it made it immediately possible to edit reporter after an F5.
Jussi Sarén September 23, 2021
I faced the same issue and this was the solution. Reporter can be seen on the "screen" even if it's not assigned to the screen and therefore it can't be edited :)
However, for me, it doesn't make sense that the field is shown on the edit issue screen even if it is NOT assigned to the screen. Should it be like this? Well, it's another discussion and doesn't belong to this topic.
5 votes
Victor
When in the said project, click on project settings and then on people. Check there if you are added as admins to the said project, if not, add yourself and whoever need to be admins in the project. That worked for me.
Fernando
This is the best most straight forward answer. Thanks!
Like Josh Simnitt likes this
March 16, 2022
Except that you probably don't want to make everyone a project admin!
Geetha June 28, 2022
@Nic Brough -Adaptavist- Is there a way to allow non-project admins to set the Reporter on an issue??
June 28, 2022
As discussed in the conversation following the answer, look at the permission scheme.
Like Geetha likes this
If the user have modify reporter permission then he can edit the reporter even though he is not a project admin?? Is it possible
Robert Mejlerö
April 7, 2024
Perfect solution
Henintsoa Rakotoarisaona
May 6, 2024
Unfortunately, this did not work for me. Does anyone have another solution, please? I can edit the reporter on initiatives but not on Epics.
May 8, 2024
There is no other "fix" for it - you need to have the "edit reporter" permission in the project the issue is in, and the reporter field needs to be on the screen.
Jack Daniel Morilla October 18, 2021
Thanks a lot! it helps me too...Cheers!
