I am running Jira 4.4.4 standalone and after a server refesh last night, We have been getting this error:
JIRA Startup Failed
Tou cannot access Jira at present. Look at the table below to identify the reasons
Description
The following plugins are required by JIRA, but have not been started:
- Gadget Directory Plugin (com.atlassian.gadets.directoy)
I have looked at similar posts, i have tried pausing the McShield Virus protection and restart it, i have removed the bundle and osgi plugin folders and nothing is working.
This logs are ginving me this error:
2012-07-13 13:25:06,610 Spring executor 18 ERROR [plugin.osgi.factory.OsgiPlugin] Unable to start the Spring context for plugin com.atlassian.gadgets.directory
org.springframework.beans.factory.UnsatisfiedDependencyException: Error creating bean with name 'feedSpecProvider' defined in URL [bundle://29.0:0/META-INF/spring/atlassian-plugins-components.xml]: Unsatisfied dependency expressed through constructor argument with index 0 of type [org.codehaus.httpcache4j.cache.HTTPCache]: : Error creating bean with name 'httpCache' defined in URL [bundle://29.0:0/META-INF/spring/atlassian-plugins-components.xml]: Instantiation of bean failed; nested exception is org.springframework.beans.BeanInstantiationException: Could not instantiate bean class [com.atlassian.gadgets.directory.internal.HttpCache]: Constructor threw exception; nested exception is java.lang.NoClassDefFoundError: javax/net/ssl/HostnameVerifier; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'httpCache' defined in URL [bundle://29.0:0/META-INF/spring/atlassian-plugins-components.xml]: Instantiation of bean failed; nested exception is org.springframework.beans.BeanInstantiationException: Could not instantiate bean class [com.atlassian.gadgets.directory.internal.HttpCache]: Constructor threw exception; nested exception is java.lang.NoClassDefFoundError: javax/net/ssl/HostnameVerifier
at org.springframework.beans.factory.support.ConstructorResolver.createArgumentArray(ConstructorResolver.java:591)
at org.springframework.beans.factory.support.ConstructorResolver.autowireConstructor(ConstructorResolver.java:193)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.autowireConstructor(AbstractAutowireCapableBeanFactory.java:925)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBeanInstance(AbstractAutowireCapableBeanFactory.java:835)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:440)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory$1.run(AbstractAutowireCapableBeanFactory.java:409)
at java.security.AccessController.doPrivileged(Native Method)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBean(AbstractAutowireCapableBeanFactory.java:380)
at org.springframework.beans.factory.support.AbstractBeanFactory$1.getObject(AbstractBeanFactory.java:264)
at org.springframework.beans.factory.support.DefaultSingletonBeanRegistry.getSingleton(DefaultSingletonBeanRegistry.java:222)
at org.springframework.beans.factory.support.AbstractBeanFactory.doGetBean(AbstractBeanFactory.java:261)
at org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:185)
at org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:164)
at org.springframework.beans.factory.support.DefaultListableBeanFactory.preInstantiateSingletons(DefaultListableBeanFactory.java:429)
at org.springframework.context.support.AbstractApplicationContext.finishBeanFactoryInitialization(AbstractApplicationContext.java:728)
at org.springframework.osgi.context.support.AbstractDelegatedExecutionApplicationContext.access$1600(AbstractDelegatedExecutionApplicationContext.java:69)
at org.springframework.osgi.context.support.AbstractDelegatedExecutionApplicationContext$4.run(AbstractDelegatedExecutionApplicationContext.java:355)
at org.springframework.osgi.util.internal.PrivilegedUtils.executeWithCustomTCCL(PrivilegedUtils.java:85)
at org.springframework.osgi.context.support.AbstractDelegatedExecutionApplicationContext.completeRefresh(AbstractDelegatedExecutionApplicationContext.java:320)
at org.springframework.osgi.extender.internal.dependencies.startup.DependencyWaiterApplicationContextExecutor$CompleteRefreshTask.run(DependencyWaiterApplicationContextExecutor.java:132)
at java.util.concurrent.ThreadPoolExecutor$Worker.runTask(ThreadPoolExecutor.java:886)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:908)
at java.lang.Thread.run(Thread.java:662)
Caused by: org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'httpCache' defined in URL [bundle://29.0:0/META-INF/spring/atlassian-plugins-components.xml]: Instantiation of bean failed; nested exception is org.springframework.beans.BeanInstantiationException: Could not instantiate bean class [com.atlassian.gadgets.directory.internal.HttpCache]: Constructor threw exception; nested exception is java.lang.NoClassDefFoundError: javax/net/ssl/HostnameVerifier
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.instantiateBean(AbstractAutowireCapableBeanFactory.java:883)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBeanInstance(AbstractAutowireCapableBeanFactory.java:839)
at org.springframework.beans.factory.support.DefaultListableBeanFactory.findAutowireCandidates(DefaultListableBeanFactory.java:671)
at org.springframework.beans.factory.support.DefaultListableBeanFactory.resolveDependency(DefaultListableBeanFactory.java:610)
at org.springframework.beans.factory.support.ConstructorResolver.resolveAutowiredArgument(ConstructorResolver.java:622)
at org.springframework.beans.factory.support.ConstructorResolver.createArgumentArray(ConstructorResolver.java:584)
... 22 more
Caused by: org.springframework.beans.BeanInstantiationException: Could not instantiate bean class [com.atlassian.gadgets.directory.internal.HttpCache]: Constructor threw exception; nested exception is java.lang.NoClassDefFoundError: javax/net/ssl/HostnameVerifier
at org.springframework.beans.BeanUtils.instantiateClass(BeanUtils.java:115)
at org.springframework.beans.factory.support.SimpleInstantiationStrategy.instantiate(SimpleInstantiationStrategy.java:61)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.instantiateBean(AbstractAutowireCapableBeanFactory.java:877)
... 36 more
Caused by: java.lang.NoClassDefFoundError: javax/net/ssl/HostnameVerifier
at java.lang.ClassLoader.defineClass1(Native Method)
at java.lang.ClassLoader.defineClassCond(ClassLoader.java:631)
at java.lang.ClassLoader.defineClass(ClassLoader.java:615)
at org.apache.felix.framework.ModuleImpl$ModuleClassLoader.findClass(ModuleImpl.java:1829)
at org.apache.felix.framework.ModuleImpl.findClassOrResourceByDelegation(ModuleImpl.java:716)
at org.apache.felix.framework.ModuleImpl.access$200(ModuleImpl.java:73)
at org.apache.felix.framework.ModuleImpl$ModuleClassLoader.loadClass(ModuleImpl.java:1690)
at java.lang.ClassLoader.loadClass(ClassLoader.java:247)
at com.atlassian.gadgets.directory.internal.HttpCache.createRegistry(HttpCache.java:56)
at com.atlassian.gadgets.directory.internal.HttpCache.createHttpClient(HttpCache.java:35)
at com.atlassian.gadgets.directory.internal.HttpCache.<init>(HttpCache.java:29)
at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method)
at sun.reflect.NativeConstructorAccessorImpl.newInstance(NativeConstructorAccessorImpl.java:39)
at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(DelegatingConstructorAccessorImpl.java:27)
at java.lang.reflect.Constructor.newInstance(Constructor.java:513)
at org.springframework.beans.BeanUtils.instantiateClass(BeanUtils.java:100)
... 38 more
Caused by: java.lang.ClassNotFoundException: javax.net.ssl.HostnameVerifier
at org.apache.catalina.loader.WebappClassLoader.loadClass(WebappClassLoader.java:1680)
at org.apache.catalina.loader.WebappClassLoader.loadClass(WebappClassLoader.java:1526)
at org.apache.felix.framework.ExtensionManager$ExtensionManagerModule.getClassByDelegation(ExtensionManager.java:672)
at org.apache.felix.framework.resolver.WireImpl.getClass(WireImpl.java:99)
at org.apache.felix.framework.ModuleImpl.searchImports(ModuleImpl.java:1345)
at org.apache.felix.framework.ModuleImpl.findClassOrResourceByDelegation(ModuleImpl.java:711)
... 54 more
2012-07-13 13:25:06,610 Spring executor 18 ERROR [extender.internal.activator.ContextLoaderListener] Application context refresh failed (NonValidatingOsgiBundleXmlApplicationContext(bundle=com.atlassian.gadgets.directory, config=osgibundle:/META-INF/spring/*.xml))
... 22 more
... 36 more
... 38 more
... 54 more
Can anyone help me?
I found it, in trying to get another Atlassian Application to run over http (still doesn't) I added diferent version of the jsse.jar, and addded jcert.jar and jnet.jar to the <jira-instal>/jdk/jre/lib. Luckily I had the same java jdk running on another machine I could copy it from. And then removed the jcert.jar and jnet.jar files then restarted and everything cleared up.
Well done Blaine
