Can't get issue key in context provider via jiraHelper
zhen zhang
May 7, 2015
Hi Everyone,
I am debugging one customized plugin, which was worked fine in JIRA 5.1.3, but not work in JIRA 6.4.1. The piece of code is below. the method-1 always return null, method-2 sometimes return correct issue key, sometimes return null. Does anyone have idea on this issue? thanks in advance!
Method -1:
String issueKey = jiraHelper.getRequest().getParameter("key");  //works fine for JIRA 5.1.3, but not ok for 6.4.1 sad
Method-2:
Map map = jiraHelper.getContextParams();
IssueImpl issueImpl = (IssueImpl)map.get("issue");
String issueKey = issueImpl.getKey(); //sometimes getKey() return null.
zhen zhang
May 21, 2015
it seems that method-2 's behavior is normal, I add exception handling solve this problem.
zhen zhang
May 7, 2015
Can anyone give me suggestions about this ticket?  Thanks in advance!
Let's build A Rovo Agent 🤖
Save your spot
