When creating an applink from Crucible to JIRA I got:
No response was received from the URL you entered - it may not be valid. Please fix the URL below, if needed, and click Continue.
Typically this messaging comes up if there's an issue with communication between the 2 servers. Check out the following article for a few tests you can run to confirm if this is the case.
https://confluence.atlassian.com/display/KB/Network+and+Connectivity+Troubleshooting+Guide
I'll also add in our guide on troubleshooting applications links as it covers most issues and scenarios one might run into.
https://confluence.atlassian.com/display/KB/Application+Links+Troubleshooting+Guide
