Can't modify Project name in JIRA 6.0.2
Rodolfo Romero
June 12, 2013
I am full Administrator of a newly installed instance of JIRA 6.0.2. I am trying to modify a JIRA Project name but when I click on the "Update" button, nothing happens and the Project name is not changed.
Zul NS [Atlassian]
January 29, 2014
For anyone who encounter a similar issue, you might have encounter the bug in JRA-33843 which has been fixed in JIRA 6.0.6.
Mick Flanigan [Equip] November 11, 2013
We are now seeing this problem on our main production instance. We tried to rename a Project, and it woudl not work, we hit update and it jsut flashes the popup and stays the same. A few days later after a restart it worked jsut fine, but then today it is no longer working, several weeks later. Filing a bug on this.
Rodolfo Romero
September 18, 2013
I've tried with Chrome, Firefox and Safari on a Mac and I got the same results. This seems to be happening only with Projects created using the wizard/template method though.
Tini Good
August 1, 2013
Theoretically possible, although the upgrade to 6.0.4 was on 7/20 and its been fine other than this one issue. I've been doing some minor tweaks to get a "clean" Hercules log scan (old accounts deleted, fixed Windows service switches, etc.), so I can't swear I've rebooted, but I've certainly stopped and restarted the service a few times to get a fresh log read. Yesterday was the first time I attempted to create a new project since the upgrade, and I typed the name wrong and then couldn't edit it.
Alejandro Conde Carrillo
August 1, 2013
Hi Tini and Rodolfo. Are you running JIRA behind a proxy server (apache)?
Tini Good
August 4, 2013
No, no proxy server.
Tini Good
July 31, 2013
No, our JIRA is on a virtual server, so we didn't use the JIRA backup restore method. All I've got are normal logs. It is interesting that the timeline is (1) can't edit project name, (2) took virtual server snapshot, (3) attempted server change for other reason, (4) restored server to snapshot, (5) can now edit project name. I'm not aware of anything in that sequence that could have fixed it.
Norman Abramovitz
July 31, 2013
I am guessing here. I am assuming you upgraded previously to your latest Jira version. You did not reboot once Jira failed, so it was the initial boot after upgrading.
Now with the shutdown, Jira was restarted and all is well.
It might just be the restart that fixed things up.
Tini Good
July 30, 2013
I have JIRA 6.0.4, same problem, tried with Firefox 22 and IE 8. Anyone find a solution to this?
Zul NS [Atlassian]
July 31, 2013
Hi Tini,
I have seen this issue before, and it seems that it has affected more than 4 users. Could you please raise a ticket in support.atlassian.com and attach along the XML backup data and Support ZIP for us to troubleshoot the issue?
Zul
Tini Good
July 31, 2013
We had an issue with the server last night and had to restore it. I went to verify the exact fields and button name to open a support request and discovered that now it works. Hmmm.
Zul NS [Atlassian]
July 31, 2013
Did you run a backup restore? Could you check if you happen to have any automatic backup created during the issue persist? It would be interesting to look into this as there seems to be a number of customer running into this.
This doesn't seems to be a bug since it is not reproducible on a vanilla instance. Most probably it is data related, but have not yet found a root cause yet.
Anyway, glad to know that it is now working smoothly on your end. :)
Geert Truyen July 8, 2013
I am having the same problem.
Jira v6.0.3.
Browser is Safari 5.1.7.
Norman Abramovitz
July 5, 2013
You did not state which browser you are using and I cannot tell from the screenshot either, but it worked on ie10/firefox/chrome (windows 7) on 6.0.3. Maybe trying a different browser would help. If it does, then clear the cache of the 'broken' browser and try again.
Ram Muthiah
I have 6.0.1. I edited the project and changed the name. It works.
Rodolfo Romero
July 4, 2013
Oh! I just noted that the functionality was added! Great! It was about time! Here is the screenshot. When I click on update, nothing happens.
Rodolfo Romero
July 4, 2013
I don't have any place where I can host an image. I guess I won't be able to add a screenshot if there is no functionality provided in "Answers" to do that. It is odd that this is not possible here.
Zul NS [Atlassian]
June 13, 2013
Host the image somewhere online, and when commenting, click on the tiny image icon to attach image from a URL
Rodolfo Romero
June 12, 2013
How can I add a screenshot here?
Jobin Kuruvilla [Adaptavist]
June 12, 2013
Can you add a screenshot of how you are editing it?
Register now
