Can't save attachment to issue
jiraguy
When I try to attach a file to an issue, I get the below error:
  • Cannot attach file risk.txt: Exception trying to establish attachment directory. Check that the application server and JIRA have permissions to write to it: com.atlassian.jira.web.util.AttachmentException: Cannot write to attachment directory. Check that the application server and JIRA have permissions to write to: /opt/jira/jira-home/data/attachments/HQA/HQA-611
Any ideas? I am new to Linux and I'm not positive on how to solve this.
Faisal
November 22, 2012
Hi there,
From the specified error message, it seems that this may be cause by the folder permission issue, whereby the user (OS) which is running JIRA may not have the permission to write on the home directory.
Therefore, can you kindly check if required, grant the user the read/write/modify permission to the home directory (and it's contents) and see if it helps?
Cheers.
Zul NS [Atlassian]
November 22, 2012
Like • Alexander Finch likes this
Kota Sreenivasa Shravana Kumar
We also faced the same issue. After changing the permissions of attachments folder in Linux to jira resolved the issue.
However, why did this happen ? Was there a configuraiton issue ? or someone changed the ownership of attachments folder to root ? we could not figure it out.
You have any clue ? Thanks
David Lopez
January 18, 2018
The same happened to me.  I suppose that Jira might have been started manually as root, what caused root ownership on attachments directory.
Vishnukumar Vasudevan
Could be the limitation of ext3 file system as well.
Please refer :
https://confluence.atlassian.com/display/JIRAKB/Error+Occurs+while+Creating+Attachment
Thanks, Vishnu.
Register now
